Learn F5 Technologies, Get Answers & Share Community Solutions Join DevCentral
Filter by:
  • Solution
  • Technology
Answers
2016 SharePoint Migration/re-direct
I would like to know if it is possible to write an irule that reference 2 different data group lists. first list would hold a list of 2010 sharepoint sites and the second would hold a list of share point sites that have been migrated to 2016 from 2010. Is this possible? we have over a 50 sites and I would prefer to manage data group lists during the migration rather the irule itself. Bob
0
Rate this Question
Answers to this Question
placeholder+image
USER ACCEPTED ANSWER & F5 ACCEPTED ANSWER
Yes, it is possible.
You can use multiple data group in an iRule, and direct the traffic to the 2016 or 2010 pool.
Here are a few links that can help you:
https://devcentral.f5.com/wiki/irules.class.ashx
https://devcentral.f5.com/wiki/irules.pool.ashx
https://devcentral.f5.com/wiki/irules.uri__host.ashx
0
placeholder+image
I suggest to create only one datagroup with path as key and pool as value
/app1 := pool-sp2010
/app2 := pool-sp2010
/app3 := pool-sp2016
/app4 := pool-sp2016
Then read datagroup matching this condition
if {[set sp_pool [class match -value [HTTP::path] starts_with SHAREPOINT_DG]] != ""}
If it matches, assign pool with
pool $sp_pool
0
Comments on this Answer
Comment made 1 week ago by Robert 1
So if I am only using one DG then would I have to reference default when parameters are not met, with default being the 2010 SP environment. Also, I want to thank all of you for your understanding as irules are not my forte. My requirement is to migrate sharepoint sites in batches under the same URL.
0
Let me rephrase my requirement. I need to redirect sharepoint sites after migration under the same URL/VS.
0
I think I got it. here is what I have. when HTTP_REQUEST { if {[set sp_pool [class match -value [HTTP::path] starts_with SP_Sites]] != ""} { pool $sp_pool }
0
The DG now look like so /site1:pool1 /site2:pool1 /site3:pool2 /site4:pool2
0
so with URL of https://sharepoint/sites/site1 it will redirect to pool1 correct?
0
Comment made 1 week ago by Stanislas Piron 9995
exact.
you can use this code to manage not listed URL
         pool $sp_pool
         pool pool1
0
Comment made 5 days ago by Robert 1
gang The above code and data grp is not working. Any ideas?
0
I cant' seems to get the pool redirection to work.
0
If anyone can help with this I would greatly appreciate it. I am truly at a loss here being a newbie to irules. :-)
0
I don't know if this helps but I am seeing "SSL Connection terminated for TCP"
0
Comment made 5 days ago by Stanislas Piron 9995
Can you post here the real irule code you use and the result of this command:
list ltm data-group internal <Name of Datagroup>
0
Comment made 3 days ago by Robert 1
here is the actual code
Rule established to redirect using pools in assocaition with site listed Data group
Site lookup occurs in "SP_Sites" Data Group
set debug 1 if {[set sp_pool [class match -value [HTTP::path] starts_with SP_Sites]] != ""} { log local0. " .. starts_with SP_Sites" pool $sp_pool } else { # if Site not in Data Group List then default to Default pool associated with Vitual Server pool SharePoint_Stg_Pool }
0
Here is the Data group Group name: SP_Sites
doeipwiki := SPPool ttts :=SPPool
0
Comment made 3 days ago by Stanislas Piron 9995
I hope this is not the exact data group configuration...
URI MUST start with /
/doeipwiki := SPPool
/ttts :=SPPool
and I don't see the pool SharePoint_Stg_Pool in your example...
0
SharePoint_Stg_Pool is the default pool for the VS
0
Uri in date group does start with / sorry
0
data group is
/tts := SPPool /doeipwiki := SPPool
0
Comment made 2 days ago by Stanislas Piron 9995
I tried the code on my lab, replacing pool assignment by HTTP response with pool info:
#Rule established to redirect using pools in assocaition with site listed Data group
    #Site lookup occurs in "SP_Sites" Data Group
    set debug 1
        #pool $sp_pool
        HTTP::respond 200 content "The selected pool is $sp_pool\r\n"
    else {
        HTTP::respond 200 content "The selected pool is SharePoint_Stg_Pool\r\n"
        #pool   SharePoint_Stg_Pool
then, I tried some URLs:
$ curl http://192.168.2.34/foo
$ curl http://192.168.2.34/ttts
The selected pool is SPPool
$ curl http://192.168.2.34/doeipwiki
$ curl http://192.168.2.34/doeipwiki/bar
$ curl http://192.168.2.34/doeIPwiki
The result is the exact match of the data group... the only part which may cause issue is if the URL doesn't match case... (last example)
0
If you want to ignore case, you must convert path to lower case in irule (and make sure all data group keys are lowercase)
    set debug 1
    if {[set sp_pool [class match -value [string tolower [HTTP::path]] starts_with SP_Sites]] != ""} {
        #pool $sp_pool
    else {
the result change with this :
$ curl http://192.168.2.34/doeipwiki/toto
0
Comment made 1 day ago by Robert 1
Doe it matter that this is all https traffic?
0
Comment made 1 day ago by Stanislas Piron 9995
Http/https is handle as equal!
0
