Karim
Apr 03, 2018Cirrus
ASM JSON/XML payload detection & Automatically detect advanced protocols
Hello team,
I have a question regarding the learning suggestions,
I want to know if it is possible for the ASM to suggest the association of an XML profile to a specific URL. In other words, is there a way to configure the ASM so that when XML traffic passes through it then a learning suggestion rises saying "you have to associate an XML for this URL"
In this article : https://support.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-getting-started-12-1-0/3.html
The Policy Builder builds the security policy as follows:
Examines application content and creates XML or JSON profiles as needed (if the policy includes JSON/XML payload
detection)
...etc
we can read explicitly that it is possible IF we enable the "JSON/XML payload detection" then the answer to my question is "Yes" . The problem is that I can't find this "JSON/XML payload detection" option in the GUI.
Could you please help on this ?
Many thanks,
Karim
