F5Audiolomb's avatar
F5Audiolomb
Oct 27, 2023
ASM::unblock not working for specific violation
Hello there,
I set an iRule for ASM that should unblock a specific violation:
when ASM_REQUEST_DONE {
    set asm_support_id [ASM::support_id]
    if { $uri starts_with "/my/uri" and [ASM::violation names] contains "VIOL_ENCODING" } then {
        ASM::unblock
This rule is not triggered for that specific violation. What am I missing?
I would also like to point out that if I remove the second part of the IF and leave just the uri match, the rule triggers just fine.
I am 100% sure the violation I am targeting is correct.
Any clues on what is wrong with it?
Thank you!
    • Nikoolayy1's avatar
      Nikoolayy1
      Icon for MVP rankMVP
      You are right as there are subviolations so the real name could be different. Still can't renember where I saw the real name with  ASM::violation details or ASM::violation_data or the command you shared.
  • please log below for confirm
    log local0. "HTTP URI: $uri VIOLATION: [ASM::violation names]"
    ASM::unblock
  • Have you set the variable $uri value before checking its content?
    set uri [string tolower [HTTP::uri]]
     As Juergen_Mang mentioned, logging both [HTTP::uri] and [ASM::violation names] can help a lot
    • F5Audiolomb's avatar
      F5Audiolomb
      Yes I did.
      I just pasted the snippet I am interested in. Please assume that the rest is in place.
      Thank you for helping with this!
  • Well... thank you all for your inputs. I logged the violation, and it turns out the violation name is "VIOLATION_CHAR_CONV".
    Where is that name coming from, I wonder? If I go to options->application security->advanced configuration->violation list, the violation name I see is the one I specified in my code above.
    So, at this point I am completely confused. The violation names in the GUI all start with VIOL_, while the violation names logged via the irule start with VIOLATION_, hence why my irule was not working.
    Why this discrepancy? All this does not make any sense to me.
    If the violation names in the GUI don't match with what I need to use in the iRules, how the heck am I supposed to find what names to use?
    BTW, I am on version 15.1.10.2.
