mhite_60883
Dec 10, 2015Cirrocumulus
So I've not used the Perl library myself (I've only used the Python pycontrol and bigsuds libraries) so I'm not 100% certain, unfortunately.
Looking at the CPAN link, though, I don't see a get_global_statistics helper function. I presume if you are using a function from that helper library, however, that it prepares the SOAP responses into the appropriate Perl data structure which would hopefully do the proper fiddling of the high/low portions of the LB response.
See this link for an explanation of the high/low stuff I mentioned:
https://metacpan.org/pod/BigIP::iControlStatistic-Methods
