Connection tracking for LB-algorithm of Least-connections(member)
Hello.
I have 3 DNS servers that I'm load-balancing with a pair of LTMs. I'd like to use the LB-method of Least-connections(member). I'd also like to set the idle-timeout to "immediate" for all DNS (UDP/53) traffic as there is no reason to keep connection information. The topology is nPath-direct server return.
My questions is:
Where is the LTM tracking which server it sent the connections to - specifically for the purpose of the LB-algorithm?
Is it "show sys connections" or some other table?
By setting the timeout to "immediate", the entries in the "show sys connections" table would be gone so that can't work with the LTM's LB algorithm.
I'm thinking its a different table but I can't find definitive information on it.
Thanks for the help.
