Sort By
- Thomas_GobetNimbostratus
What you can do is a cluster.
I suggest you to define LTM and ASM on the same configuration, you will have the best performance/security combo with that.
- mamat_132868Nimbostratus
so i should configure LTM and ASM the same configuration?where should i deploy both device..is it LTM first or ASM first after the CORE switch.
Not the same configuration but on the same platform.
And internally, it's LTM first on TMOS infrastructure.
