Sort By
- nitassEmployee
Is it possible to utilize F5 captcha engine to be used from our website?
you are taking about captcha in dos profile, aren't you?
i understand it will be used when criteria is met. even you can set it very low, it won't be triggered on the first request.
- Hussein_Ghazy_3NimbostratusYes you can use it and it is under the DoS Profile, under the ASM, create a new DoS Profile enable Application Security, Choose the captcha features and assign the DoS profile under the VS Security Tab.
- nitass_89166Noctilucent
