Sort By
- Kevin_StewartEmployee
Generally speaking, the configurable options are (only currently I hope) limited to what you can set in the profiles. That said, if 1) depending I suppose on the the optional fields you're considering, and 2) you don't care about signing or encrypting the AuthnRequest, you could layer the SP policy behind a VIP and iRule to tweak the outgoing request however you wanted.
Definitely doable.
thanks Kevin, i pretty much expect this to be the case but always worth to double check.
if i got some time ill look into the layered approach, for now ill accept the situation.
