Sort By
- natheCirrocumulus
Jlarger,
Each administration partition will have its own folder, the default is simply Common (as you may know already).
To run a query and include all administration partitions I believe you add the "recursive" switch at the end (before the output to file).
See if this works.
N
Do this ->
For a single partition:
tmsh -q -c "cd / ; list ltm virtual" > list.txt
For all partitions:
tmsh -q -c "cd / ; list ltm virtual recursive" > list.txt
KR, Dario.
