Sort By
Unfortunately, it is not in the official hotfix rollup just yet. If you need this addressed before HF4 is released, you can ask for an engineering hotfix or you can also run 11.4.1, which is not affected by this bug.
- Simon_Waters_13Cirrostratus
I suspect we'll need a hotfix, as there seem to be some mcpd issues with APM still, and I was assuming probably better to upgrade than to fix.
- Simon_Waters_13CirrostratusSorry better to upgrade, than to investigate when there are known issues already fixed.
