HTTP to HTTPS policy injecting "/Location: https:///" into URL and breaking application
We have an application I'm load balancing with my LTMs that I was initially told would just need basic load balancing and http to https redirection. Now I find out they are running it out of Citrix so they can use single signon for multiple apps and when they go to a different app it then makes a request to this one and then fails. If I disable the http-https it works in http or https. When enabled it fails trying to go to the URL: https://myapp.domain.com/Location:%20https:///ibex1h.ibx?acctnum=9248789&medrec=T01275160&cibex=&pid=&ssn=Server and I think the https rewrite is somehow inserting the "Location:%20https:///" which I don't want. I think the path should be: https://myapp.domain.com/ibex1h.ibx?acctnum=9248789&medrec=T01275160&cibex=&pid=&ssn=Server and would work. If anyone has any suggestions on how to prevent this or delete "Location:%20https:///" I'd greatly appreciate the help! The right answer would be for the application owner to alter the request they are making but in this environment it is not going to happen and I need to resolve with the LTM.
