Blue_whale's avatar
Blue_whale
Aug 25, 2021
https connection with URI shows as not secured ?
Hi Team ,
We have a new VIP with url https://example.test.com , but when we try to access the url with uri it says "The information you're bout to submit is not secure "
https://example.test.com >> WORKS
https://example.test.com/sap/saml2/sp/acs/100 >> error : "The information you're bout to submit is not secure "
Please advice .
    • Blue_whale's avatar
      Blue_whale
      HI
      VIP is on F5 on port 443 and SSL certificate in on F5 and backend servers are on port 80 .
        Blue_whale
        HI  ,
        on which tab I can find this info inside debug mode in Chrome ?
  • Hi, can you check if you have any specific iRule or LTM policy configured on the vServer to select different client SSL profile for that specific URI. And that client SSL profile's certificate is either not matching CN name with the URL or it may be expired ?
