meena_60183's avatar
meena_60183
Nov 20, 2008
Intelligent SNAT help
I need some help in understanding if I am in the right direction.
I have the following scenario.
I have 2 web servers 10.11.2.34 and 10.11.2.35 that needs port 80 (http) load balancing. I created a virtual server with a public IP of x.x.31.69 and that works fine. These servers have the BigIP as the default gateway. I can access the servers for mgmt. access like RDP etc.
Now, there is a requiremnet that the outgoing traffic initiated from these servers should appear that it is originating from the virtual address of x.x.31.69. I created a SNAT that NATed 10.11.2.34 and 10.11.2.35 to x.x.31.69.
Now, when I ping the server 10.11.2.34 or 35, I get a reply from x.x.31.69. I cannot access the servers using RDP.
I would like to restrict the SNAT only for port 80 traffic. Do I need an iRule or do I need to do something else? I am little confused on this part.
Any suggestions?
Meena
  • I created a pool called default-gw-pool and I just added the bigIP's default gateway and added that pool to the VS and it seems to be working fine now.
    Thanks everyone for your help.
    Meena
