Fernando_Clemen
Jun 12, 2019Nimbostratus
Solved
iRule redirect connection to pool on differente port
Hi!
Is it possible to redirect the connection based on the URI?
Example:
Send to mypool on port 5000
Send to mypool on port 6000
However I would like it to always be for the same pool but on different ports.
Create two pools, e.g. mydomain1.com_5000 and mydomain2.com_6000, then create a Traffic Policy with a rule for each hostname forwarding to the associated pool.
E.g.
