Jasa_74968
Mar 25, 2014Nimbostratus
iRule to check URI and Client source IP using data groups
Hi everybody, I'm trying to achieve the following with my iRule:
1. Check for URI and if its /abc/* choose pool_A
2. Check for URI and if its /abc-preprod/* also check if Client's IP is from internal pool using datagroup "internalIP"
3. If both checks under 2 are good, choose pool_b
4. Discard everything else that wasn't caught by 1 or 2
My iRule is:
switch -glob [string tolower [HTTP::uri]] {
"/abc/*" { log local0. "Detected [HTTP::uri] URL"
pool pool_A
log local0. "Production pool selected"
"/abc-preprod/*" { log local0. "Detected [HTTP::uri] URL"
if { ([class match [IP::remote_addr] equals $::internalIP]) }
log local0. "Client IP [IP::remote_addr] belongs to private network"
pool pool_B
log local0. "Pre-production pool selected"
default {
discard
log local0. "Wrong URI or Client connecting to Pre-prod from external, packet discarded"
However I'm unable to get the syntax working and it fails with:
01070151:3: Rule [/Common/***_redirect_iRule_Logging] error: /Common/***_redirect_iRule_Logging:8: error: [missing a script after "if"][ ]
Can somebody help?
