Amr_Ali's avatar
Apr 20, 2024
Solved
Port Group on F5OS network setting
what is the case that we need to configure the port Group on the F5OS rseries
  • The portgroup component is used to control the mode of the physical ports. This controls whether a port is bundled or unbundled and the port speed. Currently the high-speed ports do not support unbundling. Adjacent high-speed ports (1.0 & 2.0 on both the r5000/r10000 series) and (11.0 & 12.0 on the r10000 series) must be configured in the same mode and speed currently. Either both are configured for 40Gb or both configured for 100Gb, you cannot mix and match. You cannot break out these ports to lower speeds (25Gb or 10Gb) via a breakout cable as this is currently unsupported. Low speed 25Gb/10Gb ports (3.0 - 10.0 on both the r5000/r10000 series) and (13.0 - 20.0 on the r10000 series) can be configured independently, and adjacent low speed ports can have different speed values. The term portgroup is used rather than simply “port” because some front panel ports may accept different types of SFPs. Depending on the portgroup mode value, a different FPGA version is loaded, and the speed of the port is adjusted accordingly. The user can modify the portgroup mode as needed through the F5OS CLI, webUI or API
  • In case you would like to use link aggregate for redundant physical link for each tanents
    • Amr_Ali's avatar
      Amr_Ali
      Icon for MVP rankMVP
      but I think if I need to use two links as a redundant link I will use LAGS for the redundant physical link,s not Port Mapping
      • F5LearnerLNR's avatar
        F5LearnerLNR
        Yes the Port Group is essentially to set the port Speeds and LAG is to aggregate the Physical Links .
