Can you try after changing the interval and timeout values?
Interval = TCP.CONNECT_TIMEOUT = 60 (default)
Timeout = 181
- joelinhoAug 23, 2019Nimbostratus
2019-08-23 22:00:58,818 [DBPinger-9127] - waiting for ping
2019-08-23 22:00:58,818 [DBPinger-9129] - waiting for ping
2019-08-23 22:00:58,818 [DBPinger-23727] - waiting for ping
2019-08-23 22:00:58,818 [DBPinger-21097] - waiting for ping
2019-08-23 22:00:58,818 [DBPinger-23725] - waiting for ping
2019-08-23 22:00:59,022 [DBPinger-48803] - waiting for ping
2019-08-23 22:00:59,028 [DBPinger-48801] - waiting for ping
2019-08-23 22:00:59,067 [DBPinger-21099] - waiting for ping
2019-08-23 22:00:59,068 [DBPinger-9127] - waiting for ping
2019-08-23 22:00:59,068 [DBPinger-9129] - waiting for ping
2019-08-23 22:00:59,068 [DBPinger-23727] - waiting for ping
2019-08-23 22:00:59,068 [DBPinger-21097] - waiting for ping
2019-08-23 22:00:59,068 [DBPinger-23725] - waiting for ping
2019-08-23 22:00:59,272 [DBPinger-48803] - waiting for ping
2019-08-23 22:00:59,278 [DBPinger-48801] - waiting for ping
2019-08-23 22:00:59,317 [DBPinger-21099] - waiting for ping
2019-08-23 22:00:59,318 [DBPinger-9127] - waiting for ping
2019-08-23 22:00:59,318 [DBPinger-9129] - waiting for ping
2019-08-23 22:00:59,318 [DBPinger-23727] - waiting for ping
2019-08-23 22:00:59,318 [DBPinger-21097] - waiting for ping
2019-08-23 22:00:59,318 [DBPinger-23725] - waiting for ping
2019-08-23 22:00:59,522 [DBPinger-48803] - waiting for ping
2019-08-23 22:00:59,528 [DBPinger-48801] - waiting for ping
2019-08-23 22:00:59,567 [DBPinger-21099] - waiting for ping
2019-08-23 22:00:59,568 [DBPinger-9127] - waiting for ping
2019-08-23 22:00:59,568 [DBPinger-9129] - waiting for ping
2019-08-23 22:00:59,568 [DBPinger-23727] - waiting for ping
2019-08-23 22:00:59,568 [DBPinger-21097] - waiting for ping
2019-08-23 22:00:59,568 [DBPinger-23725] - waiting for ping
2019-08-23 22:00:59,772 [DBPinger-48803] - waiting for ping
2019-08-23 22:00:59,779 [DBPinger-48801] - waiting for ping
2019-08-23 22:00:59,818 [DBPinger-21099] - waiting for ping
2019-08-23 22:00:59,818 [DBPinger-9127] - waiting for ping
2019-08-23 22:00:59,818 [DBPinger-9129] - waiting for ping
2019-08-23 22:00:59,818 [DBPinger-23727] - waiting for ping
2019-08-23 22:00:59,818 [DBPinger-21097] - waiting for ping
2019-08-23 22:00:59,818 [DBPinger-23725] - waiting for ping
2019-08-23 22:01:00,023 [DBPinger-48803] - waiting for ping
2019-08-23 22:01:00,029 [DBPinger-48801] - waiting for ping
2019-08-23 22:01:00,068 [DBPinger-21099] - waiting for ping
2019-08-23 22:01:00,068 [DBPinger-9127] - waiting for ping
2019-08-23 22:01:00,069 [DBPinger-9129] - waiting for ping
2019-08-23 22:01:00,069 [DBPinger-23727] - waiting for ping
2019-08-23 22:01:00,069 [DBPinger-21097] - waiting for ping
2019-08-23 22:01:00,069 [DBPinger-23725] - waiting for ping
2019-08-23 22:01:00,273 [DBPinger-48803] - waiting for ping
2019-08-23 22:01:00,279 [DBPinger-48801] - waiting for ping
2019-08-23 22:01:00,318 [DBPinger-21099] - waiting for ping
2019-08-23 22:01:00,319 [DBPinger-9129] - waiting for ping
2019-08-23 22:01:00,319 [DBPinger-9127] - waiting for ping
2019-08-23 22:01:00,319 [DBPinger-23725] - waiting for ping
2019-08-23 22:01:00,319 [DBPinger-21097] - waiting for ping
2019-08-23 22:01:00,319 [DBPinger-23727] - waiting for ping
2019-08-23 22:01:00,526 [DBPinger-48803] - waiting for ping
2019-08-23 22:01:00,530 [DBPinger-48801] - waiting for ping
2019-08-23 22:01:00,568 [DBPinger-21099] - waiting for ping
2019-08-23 22:01:00,569 [DBPinger-9129] - waiting for ping
2019-08-23 22:01:00,569 [DBPinger-9127] - waiting for ping
2019-08-23 22:01:00,569 [DBPinger-23725] - waiting for ping
2019-08-23 22:01:00,569 [DBPinger-21097] - waiting for ping
2019-08-23 22:01:00,569 [DBPinger-23727] - waiting for ping
2019-08-23 22:01:00,776 [DBPinger-48803] - waiting for ping
2019-08-23 22:01:00,780 [DBPinger-48801] - waiting for ping
2019-08-23 22:01:00,818 [DBPinger-21099] - waiting for ping
2019-08-23 22:01:00,819 [DBPinger-9129] - waiting for ping
2019-08-23 22:01:00,819 [DBPinger-9127] - waiting for ping
2019-08-23 22:01:00,819 [DBPinger-23725] - waiting for ping
2019-08-23 22:01:00,819 [DBPinger-21097] - waiting for ping
2019-08-23 22:01:00,819 [DBPinger-23727] - waiting for ping
2019-08-23 22:01:01,026 [DBPinger-48803] - waiting for ping
2019-08-23 22:01:01,030 [DBPinger-48801] - waiting for ping
2019-08-23 22:01:01,069 [DBPinger-21099] - waiting for ping
2019-08-23 22:01:01,069 [DBPinger-9129] - waiting for ping
2019-08-23 22:01:01,069 [DBPinger-9127] - waiting for ping
2019-08-23 22:01:01,069 [DBPinger-23725] - waiting for ping
2019-08-23 22:01:01,069 [DBPinger-21097] - waiting for ping
2019-08-23 22:01:01,069 [DBPinger-23727] - waiting for ping
status down
- GurusApr 10, 2020Altostratus
Yes, DB connection string was pointing to port 22 instead actual DB listener port 1521.
- Aug 24, 2019
The node port seems to 22. Can you change it?
(DESCRIPTION=(ADDRESS=(PROTOCOL=tcp)(HOST=%node_ip%)(PORT=1521)) (CONNECT_DATA=(SID=swproddb)) (SERVER=dedicated))
