Problems with BIG-IP Configuration Visualizer script and CentOS 6.5
Hi we are trying to get the visualizer script to work and are having a few problems, we have installed the prerequisites as described in the the article :- https://devcentral.f5.com/wiki/iControl.BIG_IPConfigurationVisualizer.ashx
But we are still getting errors:-
Please wait while we build some maps of your system. Retrieving SelfIPs in Partition: ** Common ** Mapping Partition: ** Common ** routes to gateways. Mapping Partition: ** Common ** selfIPs and VLANs............ Mapping Partition: ** Common ** pools and iRule references to pools..................... Mapping Partition: ** Common ** virtual servers and properties.SOAP-ENV:Server Exception caught in LocalLB::urn:iControl:LocalLB/VirtualServer::get_httpclass_profile() Common::NotImplemented
The perl modules that are installed at the moment are:-
Perlmoduler som är installerade är: perl-Pod-Escapes-1.04-136.el6.x86_64 perl-Pod-Simple-3.13-136.el6.x86_64 perl-Module-Pluggable-3.90-136.el6.x86_64 perl-MIME-Types-1.28-2.el6.noarch perl-MailTools-2.04-4.el6.noarch perl-Email-Date-Format-1.002-5.el6.noarch perl-SOAP-Lite-0.710.10-3.el6.noarch perl-IO-Compress-Base-2.021-136.el6.x86_64 perl-Compress-Zlib-2.021-136.el6.x86_64 perl-HTML-Parser-3.64-2.el6.x86_64 perl-XML-Parser-2.36-7.el6.x86_64 perl-IO-Tty-1.08-4.el6.x86_64 perl-Time-HiRes-1.9721-136.el6.x86_64 perl-Net-SSLeay-1.35-9.el6.x86_64 perl-libs-5.10.1-136.el6.x86_64 perl-version-0.77-136.el6.x86_64 perl-5.10.1-136.el6.x86_64 perl-TimeDate-1.16-11.1.el6.noarch perl-URI-1.40-2.el6.noarch perl-MIME-Lite-3.027-2.el6.noarch perl-Net-Netmask-1.9015-1.el6.rf.noarch perl-Compress-Raw-Zlib-2.021-136.el6.x86_64 perl-IO-Compress-Zlib-2.021-136.el6.x86_64 perl-HTML-Tagset-3.20-4.el6.noarch perl-Parse-RecDescent-1.962.2-2.el6.noarch perl-libwww-perl-5.833-2.el6.noarch perl-XML-Twig-3.34-1.el6.noarch perl-IPC-Run-0.84-3.el6.noarch perl-GraphViz-2.04-1.el6.rf.noarch perl-Net-LibIDN-0.12-3.el6.x86_64 perl-IO-Socket-SSL-1.31-2.el6.noarch
Any help appreciated. /Craig
