Sort By
- Colin_Walker_12Historic F5 AccountWhen you say you're having trouble with this...are there any errors being displayed or logged? Is it completely failing or is only a portion of the function not completing?
- kykong_107132Nimbostratushi colin,
- The issue is a result of the pages being compressed by WebAccelerator. In order to collect the real-time stats you would need to turn off compression on the pages node in the policy. This arises from WebAccelerator performing it's optimizations first including compression before handing the response back to LTM for processing of additional iRules. Because the content is compressed the code to track real user data is not able to be inserted.
- Joe_Hsy_45207Nimbostratus
- kykong_107132NimbostratusHi everyone,
- kykong_107132NimbostratusHi All,
- If you want the html pages compressed enable LTM compression on the VS. This compression is done after all of the iRules have been processed. I've always just used the synthetic agent when testing WA as nothing needs to be changed in the policy.
