Quick and dirty shell script to find unused certificates
Problem this snippet solves:
This has been edited quite a bit since I first posted so it's probably not as quick and dirty as it was before.
This in response to a question regarding removing unused certificates https://devcentral.f5.com/questions/how-to-find-the-unused-ssl-certificates-63166
The following bash script will output any installed certificate names to a file, then iterate over each line. If the certificate is not referenced in bigip.conf in either the /config/ or within a partition folder, then it can be reasonably assumed it is not in use and can be safely deleted.
The script will give you the option to delete any certs that are not in use and save a UCS archive (just in case)
If there are any keys associated with the certificate, this will be deleted too.
As the moment, the script will not look for keys without an equivalent cert, e.g. my-cert.key and my-cert.crt. So you many still end up with rouge keys. I'll look to get this updated eventually.
There is an array called ignoreCerts
ignoreCerts=("f5-irule.crt" "ca-bundle.crt")
Here you can add certificates you may want to ignore. For example, f5-irule.crt is used to sign F5 provided iRules and bigip.conf does not reference it.
Add any additional certs to this array to ensure they are not deleted
Script can be downloaded directly from GitLab using the link below
https://gitlab.com/stratalabs/f5-devcental/snippets/1863498/raw?inline=false
How to use this snippet:
- paste into vi
- chmod +x myScript.sh
- ./myScript.sh
Code :
#!/bin/sh function buildInstalledCertsArray { tmsh save sys config partitions all tmsh list sys file ssl-cert | awk '/crt/ {print $4}' | sed '/^[[:space:]]*$/d' > /var/tmp/installedCerts.tmp # iterate over tmp file to create array of used certificates while read line; do for i in "${!ignoreCerts[@]}"; do if [[ $line = ${ignoreCerts[$i]} ]]; then ignore="true" else if [[ $ignore != "true" ]];then ignore="" else # do not add cert to array if already added if [[ ! " ${instCertsArr[@]} " =~ " ${line} " ]]; then instCertsArr+=("$line") fi fi fi done done /dev/null 2>&1) if ! [ -z "$hasKey" ];then deleteKeys+=("${cert%.*}.key") fi done } function deleteUnusedCerts { if [ ${#deleteCerts[@]} -eq 0 ]; then echo "-------------------------------------------------------------------------" echo "There are no unused certificates to delete, existing" echo "-------------------------------------------------------------------------" exit 0 else echo "-------------------------------------------------------------------------" echo "The following keys are not in use can can be deleted:" for cert in "${deleteCerts[@]}"; do echo " ${cert}" done echo "-------------------------------------------------------------------------" read -p "would you like to delete these unused certificates? (y/n)?" answer case ${answer:0:1} in y|Y ) createUcsArchive echo "-------------------------------------------------------------------------" echo "deleting certs..." for cert in "${deleteCerts[@]}"; do delete sys file ssl-key $cert echo " $cert" done if [ ${#deleteKeys[@]} -eq 0 ]; then echo "-------------------------------------------------------------------------" echo "no associated keys to delete, exiting" exit 0 else echo "-------------------------------------------------------------------------" echo "deleting keys..." for key in "${deleteKeys[@]}"; do delete sys file ssl-key $cert echo "$key" exit 0 done fi ;; * ) exit 0 ;; esac fi } function createUcsArchive { echo today=`date +%Y-%m-%d.%H.%M.%S` echo "Creating UCS archive auto.${today}.ucs" tmsh save sys ucs ${today}.ucs } # initialise vars instCertsArr=() deleteCerts=() # ignore certs defined here - f5-irile.crt is used to sign F5 iRules ignoreCerts=("f5-irule.crt" "ca-bundle.crt") # build installed certificates array - excluding certs to ignore buildInstalledCertsArray # check if installed certs are used in bigip.conf (including partitions) - ltm sys files are exluded from results buildDeleteCertsArray # build list of associated keys (not all certs will have keys) buildDeleteKeysArray # optionally delete unused certs deleteUnusedCerts
Tested this on version:
No Version Found
