Deploy BIG-IP in AWS with HA across AZ’s - without using EIP’s
Published Feb 21, 2019
Version 1.0Was this article helpful?
Hi Sebastian, yes - but you have to use a Transit Gateway to route between your VPCs. Transit Gateways were released in late 2018, and they will allow you to route between multiple VPCs. Prior to this, you needed to manage VPC peering relationships individually, and these peering relationships did not allow you to route a non-VPC IP range. (The other option prior to the release of Transit Gateways was to build IPSec VPN connections yourself between VPCs and I have not covered that here).
