Deploy BIG-IP in AWS with HA across AZ’s - without using EIP’s
Published Feb 21, 2019
Version 1.0Was this article helpful?
Hi Rafael, I deployed this template from F5's supported sample templates. I recommend doing the same. The template deployment configures default routes into a LOCAL_ONLY partition on each device, so that this default route for a device does not sync to the paired device.
