X-Forwarded-For HTTP Module For IIS7, Source Included!
Published Dec 23, 2009
Version 1.0Was this article helpful?
Hi Joe,
So we're having to use this in IIS 10 on Server 2016.
Our security team doesn't like the XFF and C-IP being separate, so I've been tasked with finding a way to merge the two, this looks like the answer.
However, on a test server, I'm not sure how to test this out and make sure it works.
I do have a custom log for the XFF field setup, not sure if that's messing with the module.
The server I'm working on is not behind the F5 and I can only connect to the host internally, though I'm using Fiddler to setup a proxy.
I'm not sure if the module is working or not.
Could you assist?
