Michel_van_der_'s avatar
Michel_van_der_
Apr 13, 2005
Compatibility issue
I'm using some perl SOAP::Lite calls, specifically
ITCMLocalLB:Pool:get_member_list which presumably is
implemented as a compatibility call. But instead of
getting something like:
ARRAY(0x8e86080)
0 ITCMCommon::IPPortDefinition=HASH(0x8eb7028)
'address' => '1.2.3.4'
'port' => 80
I get:
ARRAY(0x9557e74)
0 ITCMCommon::IPPortDefinition=HASH(0x9575678)
'address' => '-414596721'
'port' => 389
Note the address.
Thoughts?
  • Loc_Pham_101863's avatar
    Loc_Pham_101863
    Historic F5 Account
    What does your call look like? Here's some sample code that gets the pool members:
      ..... set up code, also populate $sPool variable
       Get Member List
      (@member_list) = getPoolMemberList($sPool);
      foreach my $member (@member_list)
      print $member->{"address"}, ":", $member->{"port"}, ", ";
       Get the list of pool members
      sub getPoolMemberList()
      my ($poolName) = @_;
      my @members;
      my $soap_response =
      $soap->get_member_list
      SOAP::Data->name ( pool_name => $poolName )
      if ( $soap_response->fault )
      print $soap_response->faultcode, "\n";
      print $soap_response->faultstring, "\n";
      exit("");
      else
      @members = @{$soap_response->result};
      return @members;
  • Test case below. Call it with:
    script
    My test gear runs 9.0.5. Pointing this at a 4.6 box will dump something like this:
    Pool: GSKiisT2TST 1.2.3.4:80 5.6.7.8:80
    Pool: GSKiisT2TST-s 11.12.13.14:80 15.16.17.18:80
    The test gear:
    Pool: GSKSSOIISTest 1972258726:80 1989035942:80
    Pool: GSKSSOIISTest8080 1972258726:80 1989035942:80
     !/usr/bin/perl
     require "dumpvar.pl";
     use strict;
     use SOAP::Lite;
     my ($user, $pwd);
     sub SOAP::Transport::HTTP::Client::get_basic_credentials {
         return $user => $pwd;
     sub getF5Pools {
         my $url = shift;
         my($soap, $soapResponse, $result);
         $soap = SOAP::Lite
               ->uri('urn:iControl:ITCMLocalLB/Pool')
               ->proxy($url) || die "Can't connect\n";
         $soapResponse = $soap->get_list();
         if ( $soapResponse->fault ) {
             return [] if $soapResponse->faultstring =~
               /The requested item does not exist/i;
             return "Error getting Pools: " .
               $soapResponse->faultcode . " " .
               $soapResponse->faultstring;
         return $soapResponse->result;
     sub getF5PoolsMembers {
         my $url = shift;
         my $pools = shift;
         my($p, $soap, $soapResponse, $r);
         $soap = SOAP::Lite
         $r = [];
         for $p ( @$pools ) {
             $soapResponse = $soap->get_member_list(
                 SOAP::Data->name('pool_name' => $p)
             if ( ! $soapResponse->fault ) {
                 push @$r, [ $p, $soapResponse->result];
         return $r;
     sub main {
         my ($ip, $url, $r, $p, $m);
         $ip = $ARGV[0];
         $user = $ARGV[1];
         $pwd = $ARGV[2];
         $url = "https://$ip/iControl/iControlPortal.cgi";
         $r = getF5Pools($url);
         $r = getF5PoolsMembers($url, $r);
         for $p ( @$r ) {
             print "Pool: " .
               $p->[0] . " ";
             for $m ( @{$p->[1]} ) {
                 print $m->{'address'} . ":" . $m->{'port'} . " ";
             print "\n";
     main;
     1;
  • Looks like you found a bug in the compatility methods. In the case of these methods we aren't converting the native long value of an IPAddress into it's string representation. I'll get this logged as a bug to be corrected in the next release. In the mean time, you can work around it with the following code (assuming IPv4 addresses)
    sub getIPAddress
       my ($ipaddr) = @_;
       my $value = $ipaddr;
        Look for a "." in the value to determine whether
        we need to convert to a string
       if ( $ipaddr !~ /\./) {
         my $a = ($ipaddr >> 24) & 0x000000FF;
         my $b = ($ipaddr >> 16) & 0x000000FF;
         my $c = ($ipaddr >> 8 ) & 0x000000FF;
         my $d = ($ipaddr      ) & 0x000000FF;
         $value = "$a.$b.$c.$d";
       return $value;
      sub main {
          $ip = $ARGV[0];
          $user = $ARGV[1];
          $pwd = $ARGV[2];
          $url = "http://$ip/iControl/iControlPortal.cgi";
          for $p ( @$r ) {
              print "Pool: " .
                $p->[0] . " ";
                  print &getIPAddress($m->{'address'}) . ":" . $m->{'port'} . " ";
              print "\n";
    Sorry for the inconvenence...
    -Joe
