bjorg235
Jun 28, 2019Altocumulus
Solved
Does run /sys failover standby valid to failover LTM with multiple traffic groups
I have active standby LTM pair with 5 traffic groups.All traffic groups are active on active LTM itself.I have a requirement to failover to standby for some maintenance.
- Should I go to traffic group and check all traffic groups and force to standby (or)
- run sys failover standby will simply work .
Please suggest. I am guessing option 1 is right. but option 2 can also work?? please suggest as I dont have clarity if run standby command is for traffic group-1 or entire common partition
Regards
Bjorg
Hello Bjorg
The command "run sys failover standby" will failover all your traffic-groups
For manually failovering only one specific traffic-group, you should use this procedure
https://support.f5.com/csp/article/K48900343
KR,
Dario.
