FrontmanFin
Mar 20, 2024Altostratus
Solved
Making a default route is breaking my management auth
Hello,
I have TACACS configured for Configuration Utility/GUI access and it works.
My problem is, when i make a default route on the box network > routes:
source: 0.0.0.0
dest: 0.0.0.0
gateway: (gateway ip of my internal vlan, not same as my management network)
This kills my boxes authentication with TACACS on the management side. Shouldn't the F5 reach out to TACACS on its management interface?
Resolved my issue. I made management-routes but that wasn't populating in the kernel route table (route -n from bash)
so i added the routes to my TACACs
route add -net [network] netmask [mask] gw [gateway] metric 4096
and that seems to have worked.
