  • If you have a pair of units why dont you have the standby unit sync the config over to the primary?
    Also id you have UCS archive or a prior configuration you can pull the access profile from there
  • Alexey_384's avatar
    Alexey_384
    Historic F5 Account
    Check /config/bigip.conf.bak. Possibly it's still have your policy.
  • Thanks for reply. I was finally able to get the config file from an old backup. Thanks.
  • Sil's avatar
    Sil
    After 6 years, you still CANT undo changes to access profile.
    The whole APM Editor seems to be very beta. It has a lot of bugs. If you hit such a bug, you have no chance to revert your changes this bug made to your configuration.
    I can't understand why it is not possible to revert changes! You can apply but not revert. Very frustrating.
    Now i have to restore a backup file to a production system. Perfect.
