How I did it - "Visualizing Data with F5 TS and Splunk"
Updated Dec 13, 2022
Version 2.0Was this article helpful?
Hello Joe,
There is a TMSH command required to enable AVR. Run this on your BIG-IP(s) - tmsh modify analytics global-settings { external-logging-publisher /Common/Shared/telemetry_publisher offbox-protocol hsl use-offbox enabled }.
You can modify the AS3 declaration to create resources in a different partition if necessary. With that said, the resources are deployed as 'Shared' under the Common partition. You should be able to view and attach them to your virtual(s). Note: If you do use a different partition, you will need to adjust the above TMSH command accordingly.
