Was this article helpful?
Hi MichaelOLeary and Greg_Coward
i found problem where the splunk still didnt receive any telemetry event for AVR (telemetryEventCategory=AVR) i got AVR provisoned and able to see HTTP Analytic from Statistic im also already associate the log profile to my VS, at splunk im able to see event for SystemInfo and syslog meaning that the telemety is able to send to splunk
im also done with The specific TMSH command - modify analytics global-settings { external-logging-publisher /Common/Shared/telemetry_publisher offbox-protocol hsl use-offbox enabled }. and get
# tmsh list analytics global-settings all-properties
avrd-debug-mode disabled
avrd-interval 300
disable-all-internal-logging disabled
ecm-address any6
ecm-port 0
enable-bigiq-configuration disabled
offbox-protocol hsl
offbox-tcp-addresses none
offbox-tcp-port 0
partition Common
source-id none
tenant-id default
trigger-configuration-update disabled
use-ecm disabled
use-hsl disabled
use-offbox enabled
is there anything im missing?
