Nessus 6 XSLT Conversion for ASM Generic Scanner Import
Published Sep 11, 2017
Version 1.0Was this article helpful?
Explain what you are doing...
You ran Nessus and exported the result in Nessus format? Which version of Nessus are you running?
You renamed the Nessus file to XML?
You downloaded the XSLT and ran it against the renamed Nessus xml?
Post a sample of the output so we can see what it looks like.
