iRule to set SameSite for compatible clients and remove it for incompatible clients (LTM|ASM|APM)
Published Feb 11, 2020
Version 1.0Was this article helpful?
Thanks for your replies and . Could you add this line to the samesite iRule just after the HTTP_RESPONSE_RELEASE line?
Look for this line (line 188 in https://github.com/f5devcentral/irules-toolbox/blob/master/security/http/cookies/samesite-attributes.tcl😞
# Run this response event with priority 900 after all other iRules to parse the final cookies from the application and BIG-IP
when HTTP_RESPONSE_RELEASE priority 900 {
And add this return command after it, as listed below:
# Exit this event if another iRule has already sent an HTTP response (F5 article K23237429)
if {[HTTP::has_responded]}{return}
Please test this on a separate non-production virtual server or during a maintenance window in case there are any issues.
Thanks, Aaron
