Zero Trust building blocks - Leverage F5 NGINX Plus Single Sign-On (SSO) and F5 XC
Published Jul 07, 2023
Version 1.0Was this article helpful?
Thank you Nikoolay,
Yes, if there's ability to deploy it on RE/CE for sure that article would be the one to go with.
The approach you described sounds very intersting as well
