HTTPS SNI Monitoring How-to
Published Mar 23, 2014
Version 1.0Was this article helpful?
I'm confused on why this script would be needed. If you know the hostname which you want to be included in the HTTPS probe (which seems to be a req't for this script), why don't you simply create an HTTPS monitor, then adjust the Send string to be HTTP/1.1 and include the correct hostname, e.g.:
GET / HTTP/1.1\r\nHost: sni-name.whateverdomain.com\r\nConnection: Close\r\n\r\n
That always works for me in such situations. What advantage does this script have over doing that?
